1 - 20 of 26 Posts
Car looks great [Y]
did you remove the wiper motor as well? or just the arm etc?
What grommit did you use/where from?
Yes, the wiper motor had to come out otherwise the spline would have been left sticking through the glass. It's a simple job. Pull the plastic trim off on the boot lid, its tight so a little force is required. Remove the wiper arm from the spindle and unscrew the wiper motor having unplugged the wiring loom and water tube for the washer. There's only 3 nuts holding it in place. I used a 25mm gromit from my local auto electricians to plug the hole. I did get one from Halfords but it was too flimsy. Just to be sure no water gets in I sealed the back of the gromit with duck tape. Replace the plastic trim, making sure all the clips line up and that's the job done. It's easily reversible so if I don't like having a mucky rear window the wiper blade will be going back on. Until then I'm chuffed with the uncluttered look.
Car looks great [Y]
Did you make sure to block the hose for the washer as well, if not you will get a wet boot.
1 - 20 of 26 Posts
