1 - 3 of 3 Posts
I have a noise coming from the rear wheels on my y reg (2001) 2.8 v6 4motion. When i turn a tight corner at low (<10mph) on almost full lock there is a noise from the inside rear wheel. When i say inside i mean on a right hand turn its the rear right wheel, and vice versa. Its like its turning faster than it should to keep up with the outside wheel. Its been suggested that a Haldex oil and filter change may solve it. Anyone had similar problem? Its only on tight turns at low speed, no problems otherwise.
hi mate did you eva find out what was causing the issue i have a sharran v6 4mo withn the same issue.
1 -
Haldex oil and filter change,
Rear diff oil change,
Get car scanned with VCDS and see if any Haldex faults.
2 -
If after doing all the above with no faults after scan but problem remains: Poss whole new rear diff inc Haldex required - go to a VW breakers for this as costs ?K's new.
Only other thing you could try is cleaning your Haldex pump: http://forums.vwvortex.com/showthread.php?5282607-Something-new-CLEAN-your-Haldex-pump.
1 - 3 of 3 Posts
