1 - 6 of 6 Posts
Golf V6 4Motion
Alright everyone,
Been noticing the Golf's had a huge amount of condensation this winter, realized I must have some kind of water leak when I more or less found icicles forming on the inside of the windscreen lol.
Checked the usual spots like the pollen filter housing, seals, wet carpets etc. Found a good centimeter of water down behind each of the taillights. Would this just be making its way in from the vent? Some of the flaps aren't sitting tight against the housing so would popping the vent out and getting a replacement solve the issue or is there some other way it might be getting in that I'm missing
Cheers, Chris
Automotive tire Motor vehicle Electrical wiring Vehicle Automotive exterior
don't waste your time doing that... even if they are in a better state... the problem is the seal around it... just do as instructed, take them off clean the mating surfaces and apply a nice bead than refit them. that'll sort it out.
Golf V6 4Motion
Discussion Starter · #6 · (Edited)
Small update. The silicone worked great, no more leaks in the rear however, still had a slightly excessive amount of condensation.
Had the golf up on the ramp the other day and I noticed a bit of the drivers side
carpet where a rubber grommet should be. Bit of plastic and some silicone later and the problem is all fixed.
Automotive tire Motor vehicle Automotive exterior Rim Automotive wheel system
1 - 6 of 6 Posts
