1 - 5 of 5 Posts
Diesel & RX8 Fanboy
Okay hello all!
I need some advice on dropping the back end of my car lower, i'm on JOM coilovers at present and wound all the way down at the rear. I need about another 5mm maybe 10mm. I know taking out the adjuster will give me around the 10 mark but wanted to ask about cutting the bump stops. Seen this mentioned before how much lower can you get the rear just by cutting these?
i'll be taking mine out after the MOT!! just in case he get arsey...
mine are all the way down at the mo, but i can get 1 finger and a half width in between the ring adjuster to the spring seat so around another 20mm.. will be gained well I hope.. and will bring the front down another couple of turns as well.. so no reverse rake for me!!
will only be a temp measure and hopefully the "air" will have all come together in the next month or so anyway..
1 - 5 of 5 Posts
