1 - 8 of 8 Posts
iv been searching and searching but Cannot find any link or guide on a replacement LED bulb for my rear interior lights without soldering my own on which im not going to even attempt.
Now the only other solution i have is to replace these sensor types with non sensor types......i have a clifford alarm installed so dont think id need them anymore. Would these be a direct fit replacement and would it cause a fault with the car????
Pro tinkerer
I have them in mine mate they work fine. I found that I had to trim about 1mm off the ends of the bit's that go inside the fitment, and then they fit perfect.
I trimmed off 1mm on either side, I have marked it up in red on the second pic incase your not sure what I mean.
Ok i did this mod but have noticed that these bulbs flicker now and again and also when i open doors with my fob only the front lights up but when turn ignition on then the rears come on. they do not light if i dont start ignition?????? any help
1 - 8 of 8 Posts
