1 - 2 of 2 Posts
I have an 06 Golf and the wife took it out on Saturday, an hour later I get the phone call.....'I can't get in the boot!'
I had an issue a while back where the boot lid handle failed so I replaced it, so initially I thought it must have packed up again. The weird thing is that the rear wiper has stopped working too.
Has anyone had this problem, could it be something stupid like a fuse?
Thanks in advance
Arnie
Just hazarding a guess....could be wire(s)broken where boot(hatchback) hinges are....common enough fault on mk4s....you should be able to get at lock by taking off trim panel( put rear seats down for more room) and then figure out how to operate latch...you replaced rear lock so should be familiar with it.....i always opened mine with key if battery failed so cant see why yours wont though?
Good luck
1 - 2 of 2 Posts
