hi,got new rear disc and pads for my 1.8t,got the old ones off and got the new disc back on and then screwed the pistion bk in for ages,just kept going but seems like it was right in,put the pads in and cant get the capiler back on,any help
You need a wind back tool to push and turn at the same time. It can be done with bruteforce and turning at the same time but wind back tool is so much easier.
it is fairly easy {if you have the tools} you say you skrewed the pistion in? so im assuming you have a suitable pin tool? if i remember correctly that piston can be pushed/skrewed in so its prety much flush with the caliper, bearing in mind if your brake fluid level has been topped up,you may have to remove some fluid when the pistons get pushed back,how much doesnt it fit by? cant you just skrew the piston in more? if not are the disc's roughly the same thickness? allowing for wear on your old ones.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Volkswagen Mark IV Forum
