1 - 14 of 14 Posts
hi
mk4 golf 1.6 sr 8v
wife came home complaining of a rubbing noise coming from front of car so i took it for a drive. theres a really loud rubbing noise in all gears and the car is jerking when driving the noise goes if i hold the clutch down and let the car coast but comes back as soon as clutch is released. any ideas
thanks.
no its not squealing and theres no oil leaking, theres no release bearing on this car iv never seen a clutch that looks like what i have (new clutch fitted few months back)
the release bearing is on the side of the gearbox iinside the green cover plate. the fork comes out and under that is the bearing. Cheap enough to replace only costs around a fiver and even if you get a mechaninc to change it shouldnt take more than 20-30mins
ok the gearbox is dead the diff rivets have gone and the diff housing is cracked, been told its beyond repair and cant find a 2nd hand one anywhere.
so question.....
i got a mk3 box, is it possible to fit it and change the peddle box and convert car to cable clucth instead of hydraulic. bell housing looks the same.
ok last attempt at getting this back on the road, this car had a DUU box in it. what other boxs will fit. iv been told that DUW, ERT,DLP,DUS boxs will fit. does it matter if the box comes from an 8v or 16v, dont want to spend a few hundred quid on a wrong box.
thanks.
i got the exact same car with the exact same problem, i can get a gearbox off a mk4 golf 1.6. dont no the code (should the code be on the box somewhere), mines a 1.6sr, will the box fit off just a 1.6???
please help any1 if you can,
cheers
1 - 14 of 14 Posts
