1 - 20 of 26 Posts
Hello - can anyone tell me if the RCD500 is more powerfull than the RCD300?  My late 2004 RCD300 is rubbish and sounds awfull but i used an 06 RCD300 the other day and it sounded wonderfull.- i have a GT TDi.  Any help much appreciated!
So Impatient! :p
All from the Blaupunkt site (out of interest the MFD2 navigation system is 4*25w)
VW RCD 300
Einsatz:
VW Golf V
Empfangsteil
36 Speicherpl?tze
Twin Tuner
DDA
12 FM + 12 AM Speicherpl?tze
RDS EON
Traffic Program (TP)
High Cut
SHARX
Radio-Scan
CD-Laufwerk
CD-R/RW kompatibel
Scan
Shuffle
Cue
Verst?rker
4 x 20 Watt
Geschwindigkeitsabh?ngige Lautst?rkeanpassung (GALA)
Soft Clipping
Fade
Anschl?sse
CAN-Interface
CD Changer Control
FAKRA-Anschluss
Sonstiges
Display blau positiv
200x47 Dot Matrix
Nachtdesign rot
Telefon Mute
Anti-Diebstahl-Codierung
Kompatibilit?t
BP CD-Changer in Verbindung mit Interface
IDC A09
CDC A08
CDC A03
VW RCD 500
Einsatz:
VW Golf V, VW Touran
Empfangsteil
Twin Tuner
DDA
RDS EON
SHARX
Radio-Scan
CD-Laufwerk
6 CD Changer
CD-R/RW
integrated 1 slot
Verst?rker
4 x 20 Watt
Soft Clipping
Fade
Anschl?sse
CAN
Sonstiges
200x47 Dot Matrix
Nachtdesign rot
Telefon Mute
Kompatibilit?t
VW-spezifische CDC
I still cant understand why the 2006 GT TDi sound system RCD300 sounds soo much better than the mine 2004 GT TDi?
There are two different versions of RCD300,1K0035186L (early) and 1K0035186P (later) might have somthing to do with it.
As has been said elsewhere, and in my experience, the RCD300 sound does benefit from experimenting with all aspects of the setup.
I have an 06 model rcd 300, and although the radio sounds weedy , the CD play back is acceptable ( not brilliant) but acceptable, but i find that you do have to constantly adjust the settings for bass/treble to get something that sounds right depending on the type of music u play.  Sometimes voices can be too harsh or sounds muddy, but adjusting the bass/treble controls, generally gives u something that is ok.
Hello, I have RCD500 and I can access am advanced equalization menu pressing MENU button for 10 seconds. Here you can set some filters so that sound won't be so unbalanced. The PROBLEM: I don't know how to save these settings to keep configuration after turning off... If anyone guess, please let me know...
PNS: No, this is not the standart Bass/Middle/Treble Menu. It's a menu where you can configure 3 filters for front speakers and 3 for back speaker. For every filter you can set central frequency, Gain and even Quality factor. Also you can configure the central frequency over which BMT controls act, and gain range for BMT (BMT=BassMiddleTreble).
If you guess how to save this config, please let me know, [email protected]
Regards,
Gustavo
1 - 20 of 26 Posts
