The coilpacks wont be visibly damaged but internally damaged. Get a diagnostic scan and it will tell you whats up. Hope all can be sorted for you.
Peter
Peter
Same difference as disconnecting the coil packs one by one then do like you said swap a faulty one over with the cylinder next to it to see if the fault moves cylinders or not.Heres the trick... if you can get to them? disconnect the Injector plugs individually to determine which cylinder the misfire is on? once youve found that out....switch the coil pack over to another cylinder...then repeat the process, if the misfire follows the coilpack to the cylinder you changed it to, it can only be the coil pack! if it stays with the first cylinder its either the plug, injector ...or alot of exspense. Good luck mate!
For some of us, a sick R32 would be an improvement!Hope you get it fixed mate, no one wants a sick R32 for christmas![]()
Haha sorry chap,For some of us, a sick R32 would be an improvement!Hope you get it fixed mate, no one wants a sick R32 for christmas![]()
I have in the past been disconnecting the coil packs with the engine at runnin temp...warm enough to ignite the air/fuel without the spark :| so if in doubt injectors...Same difference as disconnecting the coil packs one by one then do like you said swap a faulty one over with the cylinder next to it to see if the fault moves cylinders or not.Heres the trick... if you can get to them? disconnect the Injector plugs individually to determine which cylinder the misfire is on? once youve found that out....switch the coil pack over to another cylinder...then repeat the process, if the misfire follows the coilpack to the cylinder you changed it to, it can only be the coil pack! if it stays with the first cylinder its either the plug, injector ...or alot of exspense. Good luck mate!
well thats what i thought lol, until i got mugged of by a little 4 cylinder(forget what make the car was), i unplugged the coil packs one by one with no difference? but then when i stopped the fuel i could notice the difference! so surely the air/fuel was igniting without the spark? you tell me lol.Huh?! Air/fuel needs a spark to ignite. Its not a diesel you know.
Peter
I've had one of them go, cost about £30 to fix. Just felt sluggish and threw the engine management light on.my mates an mechanic. he put a handheld fault finder on it and it came back with an fault with a coolant temp sensor.
I've mentioned that to him, thanks. hes getting it today for me fingers crossed! My flight back to Newcastle was cancelled til tomorrow, meaning I'm around today to hopefully sort it out.I've had one of them go, cost about £30 to fix. Just felt sluggish and threw the engine management light on.my mates an mechanic. he put a handheld fault finder on it and it came back with an fault with a coolant temp sensor.
Make sure you get the upgraded green one![]()
i spoke to a main dealer. he said the 4 pin green is for the mk4 and the 2 pin grey is for the mk5. I got the wrong one!!! Doh!I've had one of them go, cost about £30 to fix. Just felt sluggish and threw the engine management light on.my mates an mechanic. he put a handheld fault finder on it and it came back with an fault with a coolant temp sensor.
