1 - 19 of 19 Posts
Hi there
im TRYING to reset my airbag light on my pd150
1. i have purchased a USB OBD II KKL Cable
2. downloaded & installed the LATEST vagcom software
3. loaded the usb drivers
4. connected lead to port under cigarette lighter
5. loaded vagcom, OPTIONS, TEST and got the following error (ive tried searching on ross tech for an answer)
VAGCOM error
Beta 506 is absolutely NOT the latest version, so I am wondering where you downloaded that version. Whether this version, nor any other version higher than 409 will ever work with 3rd party interface hardware, meaning hardware that was not produced/sold by Ross-Tech or our distributors. So what you should do is download version 311 or 409 and then try again with chosing a COM port since 3rd party interface are never native USB interfaces, they only emulate a serial port like a standard USB<>RS232 adapter.
Also since they only emulate the serial using a USB<-> serial converter the serial port could be set to something higher than com4 when installed, you need to check and maybe change it in device manager.
Chris
i noticed this too, before it was saying it was installed on COM14 which is obviously too high, i changed it to com2 and it sat there for a while and brought back the same screen "no interface found"
Thanks to all that have inputted so far, unfortunately i still haven't found a solution
heres another screen shot, ive installed version 311 as instructed, changed the com port and checked all devices that they are installed.
still no luck
would it say this even if it wasnt connected? surely it would still find the interface (cable)?
Still problems
yes, the person replied with
"i have sold 100s if not 1000s and never had problems. Try changing your interface settings"
Thanks again for your input, it is appreciated
This can get VERY frustrating as i found out! [:mad:]
May sound silly, but i am assuming, that when you connect the cable, you are conneting to the car first, and then switching the ignition on?
Honestly? This is a blatant lie, even we have every once a while a customer with problems and our hardware is settled in a completely different quality class. Sounds more like another excuse with 3rd party hardware sellers, they have no real clue about what they sell and that way also no clue to help you with problems like that.
the way im doing it all is
1. connecting laptop to cable and to the car port
2. turning ignition on
3. loading VAGCOM
i have also tried it with steps 2 and 3 visa versa
i take it this is correct?
Doesn't make a difference, in general you can exchange the steps at will as long as you make sure you are connected and the ignition is on at the point where you actually try to access the control module.
When i got my 3rd party cable i found that it would only work in one of the usb ports on the laptop and had to be set to port 3.
If you have more than 1 usb port try the others and set different com poprts to see if it will pick it up.
i bought a cable from a group buy here, ive got the 409 version and im using the usb, not any of the com ports, BUT unless i click the option "force dumb mode" it wont find the cable?! not sure what thats all about but it works for me!!?
1 - 19 of 19 Posts
