1 - 5 of 5 Posts
Hello I have a problem:
I made the retrofit of camera on my Passat CC Golf 6.
The crest rises 510 dall'rns but nothing comes out.
In the gateway of camera gives me this error:
Address 6C: Back-up Cam. Labels: 5N0-907-441.lbl
Control Module Part Number: 3C0 907 441 HW: 3C0 907 441
Component and/or Version: J772__Rearview 0042
Software Coding: 0010007
Work Shop Code: WSC 05311 000 08193
2 Faults Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Time Indication: 0
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 8
Reset counter: 96
Mileage: 12641 km
Time Indication: 0
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
I have the wrong encoding?
thanks
Okay, what car have you got? golf 6 or passat cc?
Any what car is the camera and control module out of? golf 6 or passat cc.
IIRC the parts you need to fit RVC to a mk6 golf are:
* 5K0 827 469 R (5K0827469R) - New rear badge with integrated camera and controller for RNS 510
* 5M1 970 161 AC (5M1970161AC) - Coaxial cable connecting camera with the RNS 510 Video I/O connector
* 3B0 972 722 (3B0972722) - 4 pin connector for camera (connects to new camera)
* 4B0 973 712 (4B0973712) - 4 pin controller for badge (connects to new camera)
* 1J0 973 802 (1J0973802) - 2 pin connector (connects to existing badge connector)
* 1J0 972 924 (1J0972924) - 3 pin connector (connects to reverse light fitting)
* 191 972 713 (191972713) - 3 pin connector (connects to reverse light connector on harness)
* 000 979 133 (000979133) - Connector Repair wire x 2 (3 connectors required)
* 000 979 131 (000979131) - Connector Repair wire x 4 (7 connectors required)
* 000 979 132 (000979132) - Connector Repair wire x 1 (2 connectors required)
* 000 979 129 (000979129) - Connector Repair wire x 2 (3 connectors required)
* 000 979 950 (000979950) - Webbing Adhesive (10M)
* 5K6 827 861 (5K6827861) - Mark VI Drain Tube
* 1.5m red power cable ~1mm (5 - 7.5amp)
* 5A ATM Type Mini Fuse
* Assorted small sizes of heat shrink (3mm to 6mm)
There are a few ongoing threads at vwnavi about passat CC camera's in golf 6's the consensus so far is that nobody has yet made it work including calibration.
vwnavi
So far the only fully working and calibrated setups appear to use Tiguan or Golf 6 camera's.
1 - 5 of 5 Posts
