1 - 20 of 42 Posts
Just phone them up and they didnt have a clue what a MFD2 was
They said that they prodce the housings for many car makers but the software is all VWs and they may be able to suppy a cable for pre outs if the pins on the back are the same as one of their normal headunits!
Can you get these in the UK does anyone know as he does not seem to list UK posting only germany only.
Im guessing as both the RCD500 and the MFD2 can have the optional soundpack or dynaudio pack in the passat they will both have this type of preout link, as well as the DVD version of the satnav that can now be ordered on golfs.(?1845)
Hold tight for now.....i've sussed the part numbers and will get price asap.
The quality of the German item looks kack - cheapo screened wire and crappy moulded unscreened RCA females - yeuk !
If there's enough demand, i'll be making a few sets of these - with only TOP materials !!
Let us know how it works out Foxy! The only problem I can see is getting a remote turn on signal, though i've read somewhere that someone's grafted a link from one of the CD changer connections.
Edit:-
Right I knew I saw this somewhere!
Check this page out:
http://www.crp.pwp.blueyonder.co.uk/GolfV/radio.htm
The guy is showing how he integrated his nokia hands free kit into the RCD 300, basically towards the bottom he has identified a pin that goes +12V on the CD changer port when the radio is switched on, that should do for a remote on!
Yeah - that's one of our guy's "how-to" guides.......
Here are the part numbers for the pre-out adapter plug, if you want them......if you have the CD changer lead (with CD changer or Phatnoise connected) then you won't need the green housing (plug)
You will, however, need two of the wires (giving you four terminals - you need three)
Required Parts
PartNo 3B7 035 447 B - Green housing for phone connector
PartNo 000 979 009 - Wires for insertion into connector housing. Each part contains 1 wire with two pins.
1 - 20 of 42 Posts
