Status
Not open for further replies.
1 - 6 of 6 Posts
'hi all i have a mk4 tdi110. today while on the m3 it the power steering system decides to explode, srpaying fluid every where. not impressed to be honest!
are there any general weak points within the system that i should look for?
thanks in advance'
On mine it was the actual rack itself. Give it a good look underneath if you can or take the wheels off and see if you can see it coming out of any of the track control arm joints/boots.
'just sprayed underbeath the bonnet off with a steam clean jet washy thing, the pipe which has split (more likley cut by the timing belt of something) was the pipe returning to the bottle. would i be right in thinking theres not much pressure so could do a temporry fix until i get a new pipe? my idea is to couple the rubber pipe bk together with a bit of plastic tube inserted into the rubber and jubilee clamped up'
1 - 6 of 6 Posts
Status
