1 - 20 of 54 Posts
Ok this thread is my baby so i set the rules [:D]
I think it'd be good for a new user to the site to be able to read a thread and find this information. If you aren't willing to disclose all thats asked don't post. Post everything thats under your bonnet even if you don't think it adds power. When listing power figures please post where they were done and the brand of rollers if known.
Logs of airflow,boost etc are also welcome.
1. AUM 1.8T
2. Turbo back GHL/scorpion exhaust, 3' DP with sports cat, Carbonio, Samco hoses, Bailey DV, Forge SMIC, samco TIP, Jabba chip.
3. 220bhp/220lbsft (dastek RR/ wallace performance Aberdeen) 235bhp (dynorace RR, Jabbasport)
4. Drives very smoothly, plenty of power.
1. ARX (4WD version of AUM) 1.8T.
2. Custom-Code Phase 2 remap, Custom Blueflame turbo back exhaust and 100 cell cat, Forge FMIC, 4bar FPR, Forge DV 007P, Green 80mm air intake duct, Green Cotton panel filter, smoothed OEM airbox, de-screened MAF, Samco TIP, Newsouth Performance Powergasket, Sachs G60 Flywheel, Helix G60 Clutch, GaryM Grounding Kit.
3. 239bhp/276ftlb (JBS/Piper CD2000 LOAD based Dyno - Important given that the 1.8T ECU is load based!)
4. Puts a smile on my face everytime I drive it.
1. AGU 1.8T
2.Turbo back milltek 2.5" with 100 cell racing cat, Dynatwist CAI, Custom built and fitted FMIC with GRS core and alu piping/Samco bends, Hyperboost Recirc DV, Revo code, Boostvalve MBC, upgraded to KO3S, Forge/Samco TIP, (polished inlet manifold :eek:P). <<<< added 30 bhp
3.202bhp and 236 lb/ft at stealth racing whilst on stock KO3..... 226bhp(231bhp) and 241lb/ft (256lb/ft) with MBC and ko3S at Teesside motor factors
4.Drives smoothly with MBC turned down to 1.1 bar spike and holds 0.9 to 6200rpms, (231bhp,256lb/ft) was on 1.3 bar setting and car was jerky and on/off throttle response so never really used on the road. Pulled like a teenage boys in the underwear section of anne summers!!! Upset a lot of people in BMW's
Is there anything I can do to reduce the power output of my 2.0?  Can it be chipped down?  I'm finding it a real handful - I'm frequently overtaking cyclists and even mopeds given enough notice.
Well it didnt say anythingabout 1.8t only so...
1. ABV 2.9 VR6 syncro
2. ZR2 supercharger, 248? cams, bosch green injectors, mocal oil cooler, Dastek unichip, Hayward & Scott custom downpipe back exhaust
3. 265bhp / 252lb/ft
4. Goes ok and sounds like a plane taking off
you could try putting a couple of bags of sand in the boot[:D]
AUM 1.8t
Revo Stage2
Forge FMIC
Forge 007 DV
Carbonio CAI
Milltek Turbo back with 3" high flow CAT
Hasn't been RRed in this spec, but made 220bhp and upwards of 250lbft of torque. Always had really high torque readings for some reason.
AUM 18T
Full Miltek turbo back system and 100 cel racing cat
Green filter with 80mm cold air feed
Hyperboost DV
N75J Valve
Varible boost controler
Ducted wheel arch liner and IC water mister
Jabbasport ECU mapping @ 233bhp
Also has Koni/H&R suspension, S3 braces, AmD Porsche 996 brake conversion and Black wheels! oh and ali dash trim worth another 40hp!
1. ARL 1.9 TDI 8V - 150bhp
2. Rapid digital tuningbox + Supersprint downpipe + 80mm cold air feed pipe
3. 188bhp/418Nm
4. Great torque, decent power and outstanding milleage. [:D]
AGU 1.8T
Revo
Forge 007 DV with slightly larger bore rubber hosing
Pipercross foam filter
Custom 80mm air feed
Megan Racing 2.5" downpipe
Milltek adaptor and VW exhaust system
Car hasn't been on the rollers yet and with the latest software revision Revo claim 195bhp and 225 lbs of torque.
It has much more punch since installing the downpipe and opening up the air intake.
As a comparison the Golf has been level pegged with a BMW 330Ci below the ton.
1. 2000 1.8T ARZ
2. Oettinger 235bhp upgrade with uprated Oettinger turbo and Oettinger remap, Full Oettinger stainless exhaust (now with a crack by the back box, grrr!), modified airtract, Forge DV.
3. 235bhp at Oettinger in Germany although never had it dynoed myself
4. Drives great although been experiencing some unknown power loss recently
1. 2000 1.8T AGU
2. Mongoose cat back exhaust, Collins remap, green cotton panel filter, smoothed airbox and intake pipe
3. no idea around 180 possibly 190 going to get it rolling roaded soon.
4. drives so much better after the remap makes it a true Gti i reckon. Even better once i realised the DV vacuum pipe was off!
1. 2001 1.8T AUM
2. No modifications - I lied - a jubilee clip on the intake hose!
3. 218bhp 256 ft-lb on Maha RR at Star Performance using Optimax. 227bhp 269 ft-lb on Hoffman RR at Engine Advantages (tweaked timing with vag-com, since Star run, due to using tesco 99 fuel)
4. It is torquey low down, and still spulls hard at the top. It can only be improved with better breathing.
1. 2003 AUQ 1.8T
2. Custom Code Phase 2 'Custom' remap, 4bar FPR, Turboback Milltek exhaust
with high flow Ultra cat, Forge FMIC, Forge FMCL007PA Diverter Valve,
Smoothed Airbox complete with Green 80mm Intake Ducting and Cotton
Green Panel Filter, Samco TIP, Samco Boost Hoses, EVO Heatshield Intake
Gasket, Grounding Kit.
3. 239.2bhp / 279lbs Torque at JBS Autodesigns (Piper CD2000 LOAD based Dyno) running my usual blend of
either Optimax or BP Ultimate with a bottle of Millers+ Octane Booster.
4. Upsets many other cars who seem to think they have a devine right to go faster!!
Extremelly smooth with an OEM feel and very linear power.
Peak MAF around 185-190g/s and peak boost is 1.35bar (19.6psi), holds
18/17psi, still has around 16psi at 5K, 13psi at 6K and 12psi at 6.5K.
Boost readings are not taken with a 'pie in the sky' boost gauge but are direct readings from the ECU via vagcom.
Mods, perhaps make this a sticky..... or have a section dedicated to figures and specs together with one photo ...works well for a few sites from over the pond and it is a useful resource for new comers and oldies alike
Right lets see
1. AUM 1.8T
2. Revo 4bar remap, Corbonia CAI with large green cotton filter, Samco hoses, Forge 007 D/V,
3. Running 215bhp/239.5lb on JBS rolling Rd
4. Just keep going & going & going. Till i run out of road [:mad:]
2003 Gti 1.8t AWP
gt28rs
Revo big turbo file
440 green tops
GHL turbo back exhaust
ECS pullies
CAI intake
Light weight flywheel and clutch
Eurojet FMIC
I am sure I missed a bunch of stuff, but this gives you a good idea of what I have done. I havent dyno'd yet but I am looking to be pushing 300whp.
1 - 20 of 54 Posts
