Ok,
still have the same old problem with my car. boost dropping from 15psi to 10psi back to 15psi and it keeps doing it only in gears 4 and 5 at WOT. It is intermittant but it happens more often than not. Since i've been trying to fix it i've replaced a coilpack, MAF and the temp sender. Next thing im going to try (as recommended by weeloon who has been a massive help!) is the MAP sensor. Does anyone have any additional input?
Another thing i wondered about was my mapping by jabba.
I'm spiking at 16-17psi and holding 15psi and it tails off to 10psi getting closer to the redline. Does this sound right?
If no where local can fix it then i guess i'll make a trip to Jabba (or JBS maybe) if they can update my mapping a bit for not too much.
