Poly bush anti roll bar
577 Views 1 Reply 2 Participants Last post by  Trev69
good moring,
after finding that the last owner of my golf has just sawed off both sides of the front anti roll bar i need to put in a new one but i need to get some poly bushes for it and unsure what size i need.. anyone here know anything about these ? :wacko:
mk4 1.9 gttdi pd115 y reg ,
1 - 2 of 2 Posts
it's likely 21mm as standard though could be 23mm. Measure the one you have. If you don't have vernier calipers try a 21mm spanner on it near the bush position, too small? then it'll be 23mm.
Alternatively, give you local dealer the chassis number and they should be able to tell you what it should be. Don't go down in size with the replacement or handling will be affected....that said, since it didn't have one due to being cut, you wouldn't notice
1 - 2 of 2 Posts
