1 - 20 of 22 Posts
Ok folks - I eventually got my polo/toureg rear wiper fitted after a bit of filing - annoyed, as I hate butchering anything and thought it was a straight swap? Now the wiper is juddering [:(!]
Please help before I result in re-installing the naf 'looking' original [:(]
Anyone else had this problem? Also how come some people have managed to just do the straight swap?
Would the MK5 rear wiper be a better fit? or is it the same wiper??
· Expression Intentionally Blank
It's because the old wipers are more flexible hence relatively naff at wiping and production costs for these wipers are higher than the newer type. The new style wiper has a very stiff design giving better wiping but you need to have a nice, smooth slippery window.!
HTH
Ok folks popped out yesterday in the pooring rain and put the rear wiper on - it didnt sound right at all[?]
On a closer inspection today - I can see the actual wiper arm plastic casing is about 1mm of the screen near the hinge and has obviously been rubbing too [:(] my rear screen is now scratch [:O][V][:(!]
needless to say my car is back to factory fit r/wiper [:(]
I guess some things are best left alone.... off to cry now!
You're only in Kettering. Next time you pass Silverstone Pop in and I'll grind the back off for you. My Anni rear screen is scratched where I put it on at first until I ground enough off to clear properly. Seriously I'll help you...[^] That'll mop some tears up...
· Old Skool UK-MKIV member
I think a few other people have had this problem, if its just the black plastic cover that clips over the fixing bolt, the cover can be filed or sanded down a fraction to stop it scraping on the window.
Quote: posted by adam10780 on 22/04/2004 17:26:51
Cheers Royster - just the sort of thing I needed to hear - hopefully my misses wont take the brunt of it now [:)] hay have you tried to removed the scratch marks [?]
Once again thanks for the offer.
No worries! That's what we're here for. I couldn't be bothered getting rid of the scratches can't see once the cap is on anyway!
· Premium Member
Quote: posted by Foxy on 20/04/2004 18:07:04
Adam - Rain-X is the best stuff bar-none on all your glass,
Apply to glass and to the wiper rubber.
It's not the wiper i assure you m8ey!
Someone that recommends Rain-X! I used it once as per instructions and found it terrible, had to pull over on the motorway in rain as the screen was getting so smeary, it's like grease in a bottle!
Anybody got the part # for the mk5 rear wiper, fancy upgrading to one & everbody has the skoda jobs on.
Rain-X is the dogs bollox, if you put it on correctly. You need to apply it with some kitchen roll, then when dry wipe it off with a damp piece of kitchen roll, followed by a dry bit to buff it up.It will then work amazing, I put it on all windows & mirrors.
But If you dont follow the instructions is does get very smeary.
1 - 20 of 22 Posts
