1 - 19 of 19 Posts
?<?xml version="1.0" encoding="utf-8"?><VoteOptions question="Silver TURBO badge ?" description="I bought a Silver TURBO badge and can't make my mind up whether to use it?
What do you lot reckon ?" />
i have anni gti badge with silver turbo underneath[:D]
Which doesn't look right IMO. You need the standard GTI badge to be able to pull off having the turbo one underneath. [:O]
To be honest, the one you have looks way out of proportion due to the size, whereas the regular one is roughly the same length and looks a spot on match! [:p]
Thanks for that m8, i agree. They way u have yours looks the best. can you tell me how much gap you left between the GTI and Turbo letters?
Personally i'd leave no more than about 10-15mm between the two, otherwise the spacing would be far too much IMO. Now i don't mean you have to measure it to be exact but i'm sure you'll get the idea once you place it below and adjust it accordingly. You could try positioning it with the backing still on the adhesive so that it doesn't stick when trying it out, because it is sticky!! [;)]
Ok bored.
Very rough photoshop....
Think that speaks for itself really!!
While you were at it you could've photochopped your I straight? [;)] looks a bit skew-whiff in that pic
Amazingly enough, I've had enough comments about this one! Loads of people have said the same and I agree. However, it seems that its that picture and the lighting of it that has done it. It is not like that when you look at it!
1 - 19 of 19 Posts
