1 - 10 of 10 Posts
hi
i been looking everywhere and cant find an answer... i have a strange brake light problem, my brake lights work fine, however, the right one is constantly on but very very dim and my third brake light is also constantly but very dim but only the edges of the third brake light. Its hard to describe in words so i took some pictures.
If ne1 can help would b must appricated!
http://dl.dropbox.com/0/view/e9h7xcp35di65ty/Photos/IMAG0470.jpg <---- shows the third brake light issue
http://dl.dropbox.com/0/view/8h7nwt62362tljh/Photos/IMAG0471.jpg <---- both the third brake light issue and the really really dim right brake which is constantly on
Regards,
Dan
Have seen several Mk4's drive by with this in the past, so someone must know.
Free bump for you.
My suggestion is to check the looms for damage/shorting and for a faulty earth maybe.
ill check the earth, is the earth for the lights located on the left side of the boot, behind the left light cluster?
would the brake ligh switch cause the third brake light to do that tho, i thought if the brake light switch was screwed it would either constantly keep the brakes on, or not put the brakes light on at all?
Im afraid I cant help you, but if you do discover the cause please let me know, becus i would quite like to do the third brakelight thing deliberatly...looks pretty awesome I reckon!
How does it?
Its a good way to get yourself pulled over, and a great way to fail an MOT.
Also its misleading to other drivers on the road and can therefore be dangerous.
i didnt even think about MOT, you think it will fail on MOT..great
does ne1 have ne idea of what is going on with my crazy brake lights!
Dan
Any light on the car that is not acting as it should do will cause an MOT fail, as you have to be able to switch them all on AND off and they ALL have to work correctly.
Hopefully someone will have an answer.
I seem to remember this has asked before. Have you done a search. I'd look for you but pushed for time.
1 - 10 of 10 Posts
