Phatnoise/phatbox
5.2K views 37 replies 7 participants last post by  jakeblues68
#1 ·
Hi, i read through the "offical" phatnoise thread, but you guys are just too technical for me[:$] And the phatnoise website wasn't much help. I have a gamma radio and a single in dash cd player in my bora. So i have couple of questions.
1. Do i have the correct connecting cable in the boot to connect the phatbox? i don't have a cd changer in the car, but is the cable already there and is it just a case of looking for it?
2. If the cable is there, were is it located? I practically climbed into the boot and short of ripping all the fabric off, i couldn't see anything.
3.Is the phatbox complicated to install? Remember you are dealing with someone who struggled with lego, so would i be better leaving it to the pro's?
4. Is it compatible, i heard some systems are not compatible
5. Is ?200 a resonable price for the phatbox - and is this dealer legit? http://cgi.ebay.co.uk/VW-PHATBOX-MP3-PHAT-NOISE-PHATNOISE-Changer_W0QQitemZ9737752311QQcategoryZ3293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Thanks in advance for any help, you'll be hearing a lot from me over the coming months because i am very [*-)][:cool:] about a lot of things.
#2 ·
Markus,
I have just ordered one from the same guy, spoke to him yesterday and he seems legit. The guy is called Sal and has good feedback from previous sales. The price is a lot better than the ?500 notes quoted by VW dealers.
He reckons I will receive it before Monday but has no boot changer cables, you would need to find an alternative from the bay or from a VW dealer.
Not all MKIVs have the boot changer cable preinstalled (My Bora doesn't) so you may need one if you are doing a boot install. Any existing cable should be on the left hand side (looking from rear of car) and may be coiled up under the back seat or in the boot cubby hole (back left of car).
Install should be easy, just plug into changer cable if ones there. (If not you would have to pull out the gamma head unit to attach changer cable to back of head unit). Thinking of installing in glovebox or under passenger seat in my bora.
Now I just need to swap my 6cd dash changer for a single cd and I'm good to go.
Cheers,
Ian
#5 ·
I bought one from this chap, the delivery was excellent, all you are doing is cutting out the middle man, ?199 from the Uk is the same item as the above, granted it is for an Audi, but the place sells VW also.
http://cgi.ebay.com/ebaymotors/AUDI-PHATBOX-MP3-DIGITAL-AUDIO-PLAYER-PHATNOISE_W0QQcmdZViewItemQQcategoryZ43947QQitemZ8075723584QQrdZ1
mine came to around ?120 all in, including delivery, I bought a cable from Poland for ?18, and the job was done. I also cut the 2 "wings" of the Phatbox unit, and mounted it with strong velcro, facing backwards, and didnt have to cut holes in the cubby hole door like VW say you have to!!
SB
#10 ·
I bought from the bloke in your link (Sal) and I did get my phatbox, it took a good 4-5 weeks tho, he originally said it was coming from the <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:eek:ffice:smarttags" /><st1:country-region w:st="on">UK</st1:country-region>, but ended up coming from <st1:State w:st="on">New York</st1:State> in the <st1:country-region w:st="on"><st1:place w:st="on">US</st1:place></st1:country-region>. The mains cable for the cradle was crap (the kit is <st1:country-region w:st="on"><st1:place w:st="on">US</st1:place></st1:country-region> spec, but he changes the cradle psu to a compatible) had to buy one from maplin for 6 quid.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
<o:p></o:p>
I bought my cd changer cable from the polish guy, took 11 days and its suitable. The CD changer cable is all you need extra in addition to the phatbox kit. The short cable that comes with the phatbox converts the phatbox to the cd changer cable.<o:p></o:p>
I installed my phatbox into a gamma + single CD changer, the cd changer cable goes into the single cd player and I still have the use of it.<o:p></o:p>
For starters I would recommend pulling the headunit and cd player out, and wiring up the phatbox tempory to it, making sure it plays as the cd changer, then route all the cables to the relevant location.<o:p></o:p>
<o:p></o:p>
I used to keep mine under my seat, but the frequency I remove the cart (once every week after the initial install) I ended up moving it in the boot.<o:p></o:p>
<o:p></o:p>
Little word of advice, when you plug it all in for the first time, it takes aaages (well about 2 mins) for the phatbox to update from the cart.<o:p></o:p>
<o:p></o:p>
All in all, I love it...I hacked the DMS to take a 40 gig hard disk, which is another game in itself ;)<o:p></o:p>
<o:p></o:p>
Any questions, give us a shout......cos the details around the forums weren?t as detailed as I needed.<o:p></o:p>
<o:p></o:p>
<o:p></o:p>
Imp<o:p></o:p>
<o:p> </o:p>
#13 ·
I took a few pics of my Phatnoise.
Unmolested door
Phatnoise with the wings machined off, makes it a much smaller unit.
Close up on the stainless plinth I fitted. The unit is sat on the plinth using self adhesive velcro, I have had it fitted for several months with no problems/skipping whatsoever. The unit powered up first time and worked straight away.
The rear showing the cable routing and room you have to leave to stop any crimping problems. I had to cut a small piece of carpet away, about 2 x 2" to allow the cable connecter to sit naturally.
One word, please be aware that if you buy the Audi one as I did, then you have to crimp the Audi Phatnoise connctor to the VW CD changer cable, not hard at all, and I will give you a hand on what wire goes where, or even for the princely sum of some Jaffa Cakes get the guys who did mine (I am a Mechanical/Structural Helicopter engineer but have Radio engineers working for me (Homs!)) for you.
Hope this helps, the hard part was cutting the wings off, the Alloy shroud comes off the Unit really easily, about 8 screws and a plastic fittimg, the actual Phatnoise unit inside is tiny!!!
SB
#15 ·
I ordered from Mikan Motors as above , I think they were about ?130 inc customs and shipping.
I also cut the wings off like stokeballoon, although I fitted mine to a MKV Golf under the front seat
I have the DMS hack done and a 60GB disc working, should keep me going for a while [:D]
As far as the palylists go I organised mine in alphabetical order for artist names
so my playlists are named
a-e
f-j
etc....
and then a playlist at then end called whole_disk.
Having them in alphabetical order allows me to zoom in quicker to a particular artist.
As the RCD300 in the MKV doesn't do "mix" across all disks the "whole_disk" playlist allows me to do this. The gamma in the MKIV does this anyway.
#17 ·
The parts that were used were 1J0051592A which was the cd changer cable
from my mkiv and adapter 1J0051445D.
For the Gamma, hold down the TP button for about 2 seconds.
Go to the option "CD SFL M/D" and set it to "all"
This will then play random songs across all six discs or for a Phatnoise all 300 discs [:D]
#18 ·
The plinth is actually the one I quickly made to fit a Kenwood 6 disc changer i had fitted previously. The bolt you see in the Right foreground is a stiffener I made to stop bounce.
The machining the wings was difficult, as the noise it made, because it was difficult to mount on the miller, it chattered quite a lot.
I bought from Mikan motors and they shipped in about 7 days, thehardest part was getting it from Parcelforce, as they lost it in their well organised hub! It was tracking as being in the Uk hub at Southampton, but getting it to Fareham took 4 days! But we got there in the end.
I have still to organise my playlists better, as I did it quickly in a Sunday night.
The power supply needed is 12VDC 750-1000Ma, I actually had one at home I used to charge up a torch.
SB
#19 ·
Nice Install Stokeballoon.
Just picked up a CD changer cable from the stealer and am now waiting for the Phatbox from Sal.
With regards to the DMS Hack, I have read there may be a problem doing this with the Phatbox for VW. Has anyone had any problems with their hacked cartridges? I wouldnt mind upgrading to120Gb at some point.
#23 ·
So i got my CD changer cable today. I started in the boot and routed it to the CD player at the front. One question, there is a little brown wire that is attached to, but not contained in, the main group of wires and it has a metal loop at the end, where does this go? The main cable plugs in fine, but i am puzzled as to where this born wire goes?? TIA
EDIT: has anyone mounted their phatbox vertically? i plan on doing this but everyone else has it horizontal and i am worried that it could cause some problems.
#26 ·
Mine is installed now installed vertically in the first aid box space.
Upgraded the hard drive to 80Gb following Impossibles instructions on the Phathack - an initial scare that I had trashed both drives - but up and running the next day. MP3 collection transferred and adding about 10cds a day from cd collection.
Very happy with the Phatnoise system - just waiting to replace my 6cd changer with a single cd now.
