Hi everyone.
looking for some help or advice if possible.
I have a pd150 arl Anni mk4 golf. Took it off the road to replace the engine and done a lot of work on it in the process. now my mpg are shocking after getting it back in. I haven’t done a brim to brim reading but know it’s costing me a fortune to run dash showing less that 30mpg on local 20/30 mile runs and lucky to 40 on a 100 mile plus run.
List of some of the things I done when putting replacement engine in.
New turbo
Camshaft inc belt and water pump
Injector seals
Thermostat
Tightened connection on injector loom
Fully serviced inc fuel filter
Replaced boost hoses then pressure checked so no leaks
Had mass air flow not long before engine change.
Replaced tandem pump with second hand as had slight fuel leak
I set my running spot on and torsion value is set at 0.0Ck
Injector readings are different from each other but all in spec
cyl 1 -0.19
Cyl 2 -0.66
Cyl 3 -0.26
Cyl 4 +1.15
Looks like spec is +/-2.8
vcds shows no faults. Performance I would say is down compared to how it originally was. Only thing. Haven’t changed for a while but has been changed in the past is my coolant temp sensor.
I have a friend with a arl and they getting 55mpg on small local runs.
Any help in the right direction would be fantastic.
New turbo
Injector seals
Thermostat
cyl 1 -0.19
Cyl 2 -0.66
Cyl 3 -0.26
Cyl 4 +1.15
