Pd150 Air intake pipe worth it ?
1742 Views 4 Replies 4 Participants Last post by  millington260876
i have the chance to get a pd150 air intake pipe but of a cost of ?50 is that about right for price also is it really worth it ?
and most importantly is it a straight fit to my pd100 ?
1 - 5 of 5 Posts
don't know cost wise- worth ringing a few scrappers.
you will need maf , flexi pipe and I presume this is the aluminium pipe? you may need a reducer to get it to fit to the turbo don't know if the inlets differ on the turbo's
Inlet manifold? or from air filter - TIP??
50 is expensive imho for either.
Ring a scrappers... you will need a re-map if the ID is larger or the fuel air mix will be wrong so worse performance/economy not better....
Im pretty sure the PD130 & PD150 pipes are the same...so dont go paying over the odds thinking they're different
yep ur right and i think the 110(non-pd) 100 & 115 have the same intakes etc...
1 - 5 of 5 Posts
