PD100 vs PD130 intercooler
1997 Views 8 Replies 3 Participants Last post by  madman
Sorry if this has been asked before which it more than likely has been
but is there actually any difference between the two intercoolers other than the MAP sensor
reason i ask is i have a pd130 intercooler and mine the pd100 1 is in better condition so before i swap them over i just wanted to confirm what the differences are
thank you in advance
1 - 9 of 9 Posts
check the fitting on both first before you attempt to fit it.
the 130 intercooler is slightly thicker.
might just change the map sensor to save the hassle if its only slightly thicker
the fittings should be ok as ive bought aftermarket silicone joiners
The PD130 intercooler has the bayonet style quick fit connectors. Are the PD100 rubber hoses with jubilee clips?
The pd130 cooler I've got hadn't got the bayonet style there same as my pd100
to my knowledge all the 130 had those bayonet style quick fit connectors.
Is it off a Golf?
Sorry no it's of a pd130 bora
1 - 9 of 9 Posts
