1 - 20 of 27 Posts
Hey guys
Ive had my dell dimension for about 3 years,when i first got it i added an extra stick of memory as it only came with 128MB
so i put a 512MB in aswell
the problem being the last couple of months the pc keeps crashing an a window comes up with "memory dump" in it
its pi$$in me off no end any ideas please
Stu
It could be a number of things. One of the first things to try is to
open it up and clear out any dust. Also take the ram out and reseat it.
Hi Russell
Just done that so see how it goes for a few hours,Not much dust in there tho as i did it a couple of months ago.
Stu
No it just seems to be random,although it does seem to crash a lot in the morning after not being on very long.
The reason I asked that was that it may have been related to heat. To
see if it is an issue with the ram try running it with just the
original 128 Mb and see it happens try it with just the memory you
added at after you got it.
Tried that this avo and it crashed after about 10 mins[:(]
tried it with the 512Mb and it crashed after 15 mins[:mad:]
have you looked in Event Viewer for clues ?
(right click on my computer and go to manage)
with very little information i would say maybe a software update might be causing you crash. EG: new version of your firewall, antivirus, graphics card or windows update. (serverly fragmented drive?)
System restore is pretty wick but try to a restore to an earlier date.
Are you using the same software when it does it? Have you installed anything recently?
Is it completely random otherwise?
Hi mate
still using the same software,and not installed anything else,
i did a system restore a few months back but it still does it
A friend of mine reinstalled windows and put firefox and outpost on it both of which i dont use as the outpost conflicts with my router so i always close it down
I have the same things on my laptop which is fine,just that its slower and takes ages to fire up so mainly use the desktop.
stu
Ok, note down the actual numbers etc it brings up next time you get the blue screen and post them here, will be able to give you a more definative answer then hopefully.
No blue screen it just crashes then reboots,then ya get a message sayin "your computer has recovered from a serious error"
then choose to send a report or not
thats it no warning
Well that puts a whole new angle on it, you said it was giving an error about a memory dump?
In that case, with no warning, could be your CPU getting to hot. Infact, it could be loads of things now! [*-)]
I take it you are running XP. If you are right-click My Computer and go
into Properties, then click on the advanced tab. Then click on the
settings for Startup & Recovery.
Now remove the tick from Automatically Restart and click ok until you
are back at the desktop. Now when the problem happens it will give you
a screen that gives some more info on what is causing the problem,
usually it gives the name of the file that caused the error. Try this
and post the otucome.
Sorry the first couple of times it came up with the "memory dump" notice after it rebooted,
But now it doesnt do anything it just crashes and reboots
cant be cos it gets hot as sometimes in the mornin when i turn it on icrashes then reboots then crashes straight away again[:mad:]
Thats actually a tell tale sign that it's getting to hot. It takes seconds for the processor to get very hot, not a long time. I'm not saying this is your problem though.
1 - 20 of 27 Posts
