Hi guys the other day i removed the front bumper on the golf to fit a radiator and at the same time i fitted a battery, then that was it, but when i got back in the car i noticed the outside temp gauge was not working anymore it was just showing C no numbers, so i assumed i had forget to connect it back up after the removing of the bumper, on checking i found all was in order, so i thought it must be the sensor itself, so i got a used one from breakers yard, fitted that and its still the same ??
So i then thought i must have bought a crappy sensor that was also knackered, Hence ive now bought a brand new one from VW at £23 and fitted that, Guess what still the bloody same still not working....all three sensors show the same just the C on dash, unplug it so none are fitted same again just the C...
My question is removing the battery wont have anything to do with this not working will it, (WORKED FINE BEFORE I DID RADIATOR AND BATTERY)
Or do you think ive damaged the wiring removing the bumper or something, connector looks fine no corrosion etc
Any ideas chaps greatly received
