1 - 7 of 7 Posts
2003 Bora V6, passenger side outer CV Joint Boot clamp keeps falling off. I hope to tackle this next week (when the wheel locking nuts arrive) and need advice as to how to do this properly.
When I bought the car, this clip was loose; all other wheels are fine.
When I replaced the clutch last year, with drive shaft out, I replaced the clip and used the special tool to crimp it tight.
By the time car went for a wheel alignment, it was loose. The garage reinstalled it.
I recently noticed it was loose again.
Does the boot need to slide further to the outside?
Automotive tire Coil Coil spring Gas Auto part
V6 4Motion
I re-did my CV boots due to MOT ( safety inspection) and one of them spun a small amount of grease out after a few miles - it really needed a good extra crimp with the Oettinger clamp pliers even though I'd given it a good hard crimp beforehand, it's been fine since.
I looked through my photos, I did replace the inner clip before reinstalling.
You might be right, I may need to squash the bellows up a little bit, but the inner clamp still goes in a predetermined spot.
Wood Auto part Gas Drill accessories Machine
Water Plumbing fixture Tap Plumbing Sculpture
1 - 7 of 7 Posts
