1 - 3 of 3 Posts
Banned
Anyone know where I can get bits and pieces, connectors and hoses etc to make up my own oil return line for my turbo? cant find anywhere that sells fittings for the K03 turbo.
Banned
My return line bolts onto the sump with an oval shaped flange and a gasket, same at the turbo end, the feed line is a screw in job, coolant is screw in feed and a hose with a jubilee clip for the return.
Only ive had to move my turbo over to clear my engine mounts, so of course everything that goes to or from the turbo needs adjusting, some stuff ive just cut or forced it to where it needs to be but the oil drain is no way no how going to fit.
1 - 3 of 3 Posts
