1 - 20 of 25 Posts
A bit confused as to how I am supposed to connect it to the original
loom. The original loom plug is female and looks like this ......
And the plug Im supposed to connect to it is also female [:s] It looks like this ....
Not sure how theyre supposed to connect - Im trying to achieve a plug
and play system, without splicing and dicing the looms etc.
Does anyone know what Im supopsed to do ?
thanks
Yup thats looking good.
Ive gatherd I need to get some male clips to go into the new plug si I can fit the plug into the factory loom.
In the pic, the top one if the xenon plug and bottom is factory loom plug
Thanks mate [:D]
I have two new plugs and two new sockets (10/12 pin) and some wires to make up the adapters if anyone wants them at a good price.......
Here are the part numbers.......
1J0 941 165 (12 pin plug)
1J0 973 835 (10 pin socket)
2.5mm wires for 12-pin (you need 4x off) 000 979 225
1.0mm wires for 12-pin (you need 4x off) 000 979 131
2.5mm wires for 10-pin (you need 4x off) 000 979 226
1.0mm wires for 10-pin (you need 4x off) 000 979 134
That lot should cost you around ?32
Nudda.......i'd prefer to sell you:
1J0 941 165 (12 pin plug) x2
1J0 973 835 (10 pin socket) x2
2.5mm wires for 10-pin 000 979 226 x4
1.0mm wires for 10-pin 000 979 134 x4
For say ?14 delivered........
you just then need the following (i'm out of these at present):
{NB - each wire has a terminal at each end, so you snip it in half to make two wires with terminations}
thanks but that would be totally pointless for me as I already have the plugs now. Im really just after the 226 and 134 please.
OK doode.......NP !
Retail is around eight and a half quid - call it ?5 delivered - for 4x of both.
PM me and we'll sort the details chap.
So if you have the xenons with the power pack built in, one of these adaptors would mean they plug and play ? (All but the self levelling).
My xenons have two point to plug in to tho. What is the second point for... The levellers ?
So if you have the xenons with the power pack built in, one of these adaptors would mean they plug and play ? (All but the self levelling). My xenons have two point to plug in to tho. What is the second point for... The levellers ?
1) Yes - plug & play
2) There is a mod for the lights which allows manual levelling
3) There is an unused plug on one or both lights
Any one have a clue what the other plug point is for then ?
Ill try my best macdaddy
yeh the other one if for the auto-leveling device which goes near your
suspension apparently. Not sure where to source it though ! Im just
going to go with the manual levelling via rheostat.
1 - 20 of 25 Posts
