1 - 20 of 22 Posts
as some of you know i bought -30mm eibachs to put on my golf but i aint happy with the ride hight
i feel it doesnt sit low enough compaired to the other cars i have used Eibachs on
so i am thinking of getting the -50mm ones and selling the -30mm ones
what do you think?
Thats the main reason I didnt go for springs and chose coilovers instead.
Yes they were more expensive but you never know what you are going to get with springs until your car is back on the ground and settled properly.
I much prefer the minor adjustments of coilovers.
Craig, just beware with -50mm springs as this could cause a whole new problem with a rubbing front ARB on the driveshaft
Quote: posted by craigGSI on 22/01/2005 14:28:28
might just make do and save for coil overs then
You wont regret it Craig plus you'll also benefit from the dampers as well as the adjustable height.
FK do a good range at keen price's, speak to Rich (R1GTI).
How long have you had them on mate?
Mine took a few weeks before they had settled properly - it looked just like yours did now in fact and then got progresively lower until it settled at around about -35 to -40mm
Quote: posted by zekegti on 22/01/2005 15:22:12
Why not have a look at the current group buy. ?400 is pretty good value for a set of coilovers
i have just been reading that buddy
will see how finances are in feb as ade is offering them for ?400 without a min number of orders [:D]
You will still have arb and driveshaft problems with coilovers.
You will need either :-
1. adjustable drop links with the stock ARB or
2. aftermarket ARB with more clearance or
3. KW coilovers as you can then use the R32 ARB which links differently.
personally I have speed bump issues with a 30mm drop so wouldn't want to go any lower.
Craig, did you fit Eibach or any other sort of shortened dampers as well as the springs or was it a springs only job?
Reason i ask is, I've been wanting to lower the Bora for quite a while now and had finally decided on the Eibach 'pro kit' 30mm drop with springs/dampers mainly as i dont want to go too low for practicality reasons, and i have heard that the Eibachs offer the best ride quality which is very important as the roads round mine are terrible
Yours is not the first report i've heard about being dissapointed with the drop given by the Eibach's so i'm still undecided about them as i don't want to get them and wish i had gone down the coilover route
I have heard that if you don't use shortened dampers, the Eibach springs will not give the full stated drop, so i'm just curious as to which setup you have mate..
TIA [:D]
Steve
Craig, as u know i'm on a 50mm drop on eibach springs and shock, and i'm well happy with the look of the drop and the ride aswell
and we don't have a problem with the anit roll bars rubbing like the petrol dudes have[:D][:D][:D],
slam it mate[8D][8D]
so if mine is like yours Gerard (a tdi) then i will be ok to drop it 50 with decent shocks
also where did you get your shocks to go with the springs?
i see venom motorsprot do a set of 4 sprots shocks for ?150 is it worht buying these with the eibachs?
yours will be fine mate, your car is exact same model as mine, the early diesels have a thiner anti roll bar hence we don't have problems like the GTI's.(well thats what I've heard anyway)
i got Bedrock to do the drop on mine, they supplied and fitted it all,
I'm not sure about different make stuff tbh,
Quote: posted by craigGSI on 24/01/2005 20:14:14
what was the total cost mate ?
lols @ you graigGSI - well and truly bitten by the dub mod bug. [:D]
Car looks smart with those alloys mate, BTW - how much, if it's not being impolite to ask?
1 - 20 of 22 Posts
