Thanks for that NP. I have an update and things are starting to (possibly) reveal themselves. I've not got a great knowledge of how things work but I'm learning!
So far: Filter change, complete mess up didn't prime filter correctly, lots of air introduced by cranking and cranking until the battery eventually died.
So the problem was air introduced to the system by me at the filter. Fix? To bleed the air from the fuel system to allow the pump to pull the fuel from the tank into itself and then to the injectors. All under vacuum? ie. a closed circuit no air? Think I'm learning.... Or not lol
Racing ahead a friend said to use ez start and it would just pull the fuel through eventually. I tried this and it would run on the fluid but I still wasn't getting enough diesel through. So there's been a lot of cranking once more!
So with a recharged battery I follow the guides online and prime the filter and pump then crank the engine with the injectors cracked then retighten. This didn't seem to work although I almost got it to start a couple of times... I think I've got a leak letting air in. So I check the lines visually and pull fuel from tank, get it to the filter get it to the pump and try again. I still couldn't get the air out! I was letting some in every time I removed the vac. The fuel would race back to the tank. Eventually I learn to clamp the hose and quickly reattach it before it syphoned backwards.
I fill the tank with more diesel and try again this time with no visible air in the lines. Hey presto it starts after a prolonged crank! But won't rev and quickly dies after 10-15 secs. Gutted. Stumped. lost. Possible to still have air in there. A friend suggests to check the pipes from the tank. I undo all the false floor remove the bulkhead (it's a caddy van) and test the fuel lines are holding vacuum... Which they are. Great. So it's definitely getting fuel and no air from the tank. Again I prime everything up and try again. Now it fires up and idles but runs like absolute garbage. Loads of smoke, coughs and splutters, won't rev above 2krpm sounds awful and I think I've killed it. Sad face. I still don't think I've got a leak in the pipes. (and still don't)
This is after you had suggested a tow so I've made progress. I tell my friend and he says take it for a drive! Good idea! So I venture out around the corner and up the road, smoke billowing from the exhaust other motorists backing away as I trundle towards a roundabout. I get scared as things didn't improve so pull u-turn and manage to get home without stalling. Hmmmmm
There's a mk2 caddy page on fb that I get parts and advice from so update everyone with my troubles. A guy mentions timing. So with vcds I check basic settings 004
I rush ahead and try adjusting the ignition timing thinking this was the problem. I managed to change the ign. timing to 15 btdc and it starts a lot easier but obviously 15 btdc aint good so get it back to 1.5 btdc. I have noticed occasionally the early text changes to late as the engine is running. I'm guessing this is bad? In the youtube vids it mirrors the btdc value on the right. No where does it say early and fluctuate between late.
Is this the symptom of a knackered pump?
Is there anything else I can check?
Once again thanks for bearing with me! This is has been an absolute ordeal but I'm not giving up!
Another little update: The van doesn't have as many sensors and measuring settings in vcds as my mk4 golf but I've found a few things relating to the injectors I think. Injection quantity, mg/stroke/voltage and other flashing numbers lol
I've also got a multimeter so will learn how to test the pump harness. I read a thread about a guy replacing his pump, then an injector but it was an issue with his ecu not sending power to a pin on the pump harness.
Further update: Managed to check the timing with a graph! This looks to be good but I do have a fault code that clears but seems to return: 1756 start of injection timing regulation p1248 - 35-00 . I'm looking into this now. Again it's running really bad, incredible hard start apart from the one time I had 15btdc
Further, further update: Researching the above code has led me to this video:
He runs an output test on the n108 valve that is responsible for timing the pump with a valve (I think) . The engine tone should change as it cycles on and off. Mine doesn't and neither does his. Although his car drives fine....
