i might be wrong,, but i`m sure the pd130 and pd 150 both have 6 speed gearboxes,, the others only have 5 speed
You're nearly right. The PD 115, 130 & 150 all had 6 speed box's. The rest had 5 speeds.i might be wrong,, but i`m sure the pd130 and pd 150 both have 6 speed gearboxes,, the others only have 5 speed
If its a common rail, then its not a PD engine.Oh balls about the Head gasket, would explain the turbo acting wierd, I ill give you an example, turbo spools up , then backs off boost slightly at around 2K and the boosts again up to 3k and then drops off boost again then , it is out of it's power band to 4K. Right time for answers to your question about the shunt, it is a front end shunt, I can see the different paint colour on the front quarters and bonnet. it is a common rail system, so my dad says and he knows diesels. now how to find out with pd it is.
