1 - 18 of 18 Posts
Ive got a couple of questions about the n75j valve.
That will probably make me sound really thick but here goes anyway...
Why is the n75j valve any different to the factory one it replaces??
Why does it need to be fitted in reverse?? (as recomended by Simon Coe of CCC Tech)
What will it do for my Upsolute chipped AGU 1.8t??
the n75j just allows the wastegate of the turbo to be opened for longer. therefore in theory giving you an extra few psi of boost. i tried the h valve with my revo chip and it was poo poo. you don`t fit them in reverse, its the plug connector that faces rearwards instead of forwards.
who are ccc tech anyway?
IIRC, CCC tech are the company who d the upsoluet remaps. Not sure if Simon runs/owns or just works for 'em, but i've not heard a bad word about Simon.
PS, Where do / have you guys bought your N75J's ??
I have my golf Upsoluted and I have the N75J valve fitted in reverse. The valve controls the wastegate and spools the turbo up earlier than it would with the standard valve. I fitted it in reverse because it seems to work better that way, it brings the boost in earlier and holds it on for longer. Fitting this valve will give you slightly more power in your car as you are getting the boost earlier.
Best thing to do is put it in the right way, go for a drive, then take it out and put it in reverse and go for a drive again. See if you notice a differnce in reverse. Different engine codes give slightly different results with wee things like this.
Bought my N75J from www.vagparts.co.uk and i think it was ?35
hope this helps
cat
hope this helps
cat
Cheers Cat. Mine is AGU (non upsoluted, atm) would it give a difference or shall I just wait til I upsolute in a coupla months time ?
cat
think i`m confusing myself a bit now. what do you mean by reverse??? as in the wastegate bit swapped with the intake bit??
I think it's very misleading to talk about connecting a n75 in reverse especially as some people do actually have their DVs connected in reverse which is a completely different thing.
AFAIK the long pipe of the n75 ALWAYS points downwards and fits into the turbo intake hose regardless of which n75 you have. The electrical connector for the n75j faces the firewall where as the other n75 variants have the connector facing the front of the car.
job done, put it in normal but clip the plug in the other way. (however my n75h is the right way )
Just to add some fuel to the fire here.
I decided to re-fit my bleed valve on Sunday and hadnt really driven the car on a proper dual carriageway until this morning.
All i can saw is wow what a difference to the N75 it makes.Only running 10 psi (0.7) bar but the pull in each gear is great.Will hold 10 psi in every gear too.
Worth a try in my opinion.
hope this helps
cat
How do you know what n75 calve is the "J" type all I can see on VAGparts is N75 Golf, Seat or S2?
hope this helps
cat
How do you know what n75 valve is the "J" type all I can see on VAGparts is N75 Golf, Seat or S2?
What puts me off one of those is that you lose the progressive delivery that you get with the Golf. It becomes a bit more like having a turbo switch, which I think could become tiresome in every day driving, though fun when you want to boot it. Just my 2 cents.
I hear ya but it honestly aint too bad when just running relatively low boost.When i get time i will try some other configurations to get even smoother delivery.
1 - 18 of 18 Posts
