1 - 20 of 41 Posts
Here's the calipers:
http://www.uk-mkivs.net/photos/sem/images/302442/original.aspx
and some rusty discs!...
http://www.uk-mkivs.net/photos/sem/images/302443/original.aspx
The rust was removed using a drill wire brush attachment thing and then degreased. I decided to mask the disk up and paint the bell and edge to prevent further rust and discolouration of Anni wheels. I used Hammerite Smooth Silver and applied four coats...
http://www.uk-mkivs.net/photos/sem/images/302446/original.aspx
6 hours with a flapwheel/wire brush on drill I got the calipers and carriers down to a surface that was suitable for painting:
http://www.uk-mkivs.net/photos/sem/images/302447/original.aspx
http://www.uk-mkivs.net/photos/sem/images/302448/original.aspx
http://www.uk-mkivs.net/photos/sem/images/302450/original.aspx
All masked up and ready to paint....this took me ages!!
http://www.uk-mkivs.net/photos/sem/images/302451/original.aspx
I made this stand to hold the calipers upright for painting [:)]
http://www.uk-mkivs.net/photos/sem/images/302459/original.aspx
.....and after 5 coats of Hammerite Smooth spray, here's the carriers (and my sisters old duvet cover)
http://www.uk-mkivs.net/photos/sem/images/302460/original.aspx
Then the calipers were painted, again 5 coats of Hammerite smooth spray. In total, I used 3 cans...
http://www.uk-mkivs.net/photos/sem/images/302461/original.aspx
I left them for 2 weeks to dry in a warm room, here's the kit with masking tape removed and ready to be fitted:
http://www.uk-mkivs.net/photos/sem/images/302463/original.aspx
Really pleased with the end results, they look almost look as if they left the factory like this!
Fitted at last!!!
http://www.uk-mkivs.net/photos/sem/images/302474/original.aspx
http://www.uk-mkivs.net/photos/sem/images/302475/original.aspx
The finished product:
http://www.uk-mkivs.net/photos/sem/images/302426/original.aspx
Looks great Sem and you have made a really nice job of the painting.  The Hammerite Smooth on the callipers should be fine but I would expect the paint in the disk vents will burn off with some provocation!  Great pic of the disc behind the wheel - how it should have left the factory!
Yep they look the nutz mate! nice job! how does hammerite fair with the heat build up?
Hammerite is perfect.
I used it on my front calipers and carriers on my 312's which I had for
nearly 18 months and the rears which are now 2 years old - no flaking
or bubbling.
More importantly though, its stayed as red as it was the day I sprayed it on.
Sem, your works as always is top notch.
Well done [Y]
Although the brakes had previously covered about 5,000 miles before being removed from the R32, I have still been trying to bed them in gently.
Initial impressions are good, I shall give them a proper test towards the end of the week as I will have covered about 350 miles on them.
Cheers for the comments.
After about 250 miles this week of gentle braking, they seem to have bedded in nicely. The stopping power is just awesome!! a big improvement over the original 312mm setup.
As for the painting services - it's really not that difficult. The key is to preapre the surface properly. The preperation stage is what took the longest - the actual painting only took a couple of hours.
The brakes were painted over 3 weeks ago and is curing nicely - it seems to be rock hard now, I guess the heat generated from the brakes has helped.
These look simply amazing, I have a question though
How did you tape up the discs for painting? In the pic where they are taped up it looks like you've painted quite a lot into the disc, but in the pics where its fitted its just a small lip of the disc thats painted... I don't get how it got from A to B!?
Also can I fit R32 brakes to my 1.8T? Do I need anything else apart from discs pads and callipers?
1 - 20 of 41 Posts
