I sweat to you that I have a feeling that it might be unplugged 🫣, I say that because after reading about the EPC, I went to have a visual check and found that I hadn’t tightened the throttle body pipeDoes it rev up as normal? If it doesn't rev at all, then is the throttle body plugged in? Not trying to insult your work, it's an easily missed plug.
Other thoughts that come to mind is that timing could be out, that'd cause rough running, but I'm sure that'd still let it idle a bit lower.
I'd do a compression test and check the timing again if it were my car. I'd also leave the battery disconnected for a while to see if that gets the car communicating with Carly again, there's got to be a code stored if it's indicating an engine fault.
Yeah, my back still hurtseither a simple sensor like the camshaft sensor isn't plugged in or you forgot to put in the MAP or MAF sensor.. something simple as that... just go over it again you'll find the culprit, once you've rested a bit.
Told you it was easily missedDude, I’m such a lucky boy, I didn’t plug the throttle body in
Yeah dude the Force is with meI told you it was something simple... so it is running properly now? Remind me what day it is... yeah that's right: may the forth be with you![]()
Thanks for the encouragement, really needed it.Told you it was easily missedGlad to hear it wasn't serious!
