Thanx Phil!
Quote: posted by rs_t on 06/10/2004 07:26:28
Beddie: They sure are nice mate! What is the different from the OEM and the Hellas? I belived Hella was making the OEM tails?
Not sure as Hella do make the OEM item. The cheaper 'Hella' ones were not available when I got mine, so mine are OEM - I think the only difference is probably that, they are OEM and have VW part numbers. Mind you as they are so cheap anyway maybe go with the OEM ones. Just so you know you will need two orange lensed indicator bulbs and to drill a hole in them for your fog light - there is a blanking plater where your fog needs to go. Easy to do though.
