1 - 1 of 1 Posts
Car is running very lumpy on idle, only once car has reached
operating temperature though, done every logical check i can think off
but still no luck. Need desperate help with this as the car is my daily. these are the results of what i tried tonight with vag com and at what time intervals.....
19:49 - Car mildly warm, reading 55 on temp gauge. Seemed to
take longer to start than normal, no misfire counts
19:51 - Pulled away and moved the car 100 meters up the
road, car sounds lumpy at idle however no misfire counts through VAG Com. Temp
at 75 degrees.
19:53 - Again, drove 300 meters no misfires or signs of
hesitation.
19:57 - Normal driving, misfire counter reading misfires on
cylinder 4.
19:57 - When pulling away extreme hesitation and misfires on
cylinder 2 and 4, engine management flashing.
19:59 - Pulling away, feeling of boost issues, possibly limp
mode but with no engine management light.
20:04 - Excessive misfire counts on cylinders 1, 2 and 4
when accelerating.
20:17 - When at idle cylinders 1, 2 and 4 counting misfires.
20:19 - When building up the revs again excessive misfires
across the board and flashing EML.
20:31 - Excessive popping and banging on run down from 4,000
rpm.
20:36 - When driving briskly misfires only been counted on
cylinder 4.
4x Plugs Changed
4x Coil Packs Changed
No fixed EML present on dash.
I also currently have no brake lights working
but all bulbs are fine and have not blown as rear lights work with
dipped beams on but do not light up once brake pedal is pressed. Could
this be an earth fault somewhere??
fault codes off VAG COM:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 01271 785 00200
VCID: 347A0B222EBD
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 01271
VCID: 2154F276814F
2 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
01271 - Positioning Motor for Temperature Flap (V68)
37-10 - Faulty - Intermittent
Friday,11,February,2011,18:26:37:57976
VCDS Version: Release 10.6.3 (x64)
Data version: 20101206
Control Module Part Number: 1C0 907 379 M
Component and/or Version: ESP FRONT MK60 0102
Software Coding: 0019970
Work Shop Code: WSC 01271 785 00200
VCID: 347A0B222EBD
3 Faults Found:
013 - Check DTC Memory - Intermittent
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal - Intermittent
00526 - Brake Light Switch-F
any help at all on this would be appreciated guys, thanks
1 - 1 of 1 Posts
