1 - 20 of 23 Posts
Now if that works it's awesome!
As I've posted previously Phatnoise modded my box free and it works
faultlessly with my MFD G, they said it was an EEPROM change to cure
it. But also said it was all down to the different clock voltages on
the pcb, so this mod does make sense
However, the phatnoise is truely an awesome system and I may now get a
second one to chuck in the Sharan [aka kids party bus] cos they are
sooooo cheap from the u.s is mad.
This mod is very simple to do by the looks of it too[:D]
Good find Zak!
BORA owner!!!!!!
Hi, as a8wpg stated there are two ways that the phatbox can be converted to run properly, the first is the change of eprom, ive been looking on the satnav forum, and its quite difficult, but the chip is available from the a US electronics store, or the easier method which i,ll do first is the jumper wire method and the updated phatnoise firmware, if it makes it work properly i,ll stick with it!, it also gives me a chance to trim the ally phatbox down so that i can fit it either under the seat or in the glovebox.
zak[:)]
Just done this mod to my Phatnoise which is controlled by a version D MFD.
I haven't been on a long drive yet to fully test it but can confirm the Phatnoise and navi unit still work!
I shall know for sure next week if it fixes the skipping/crashing out to FM issue.
I will have to pull the phatbox out later to get the part number mate.
Tips - use a good quality soldering iron with a very thin pencil tip. I use a Weller temperature controlled unit. Make sure you tin the ends of the jumper wires and only use a small amount of solder when soldering them to the motherboard. If you use too much you risk bridging the other pins. There is not much room to work with so take your time, check and double the connections that you have made with a magnifying glass to ensure you have not shorted anything.
I was quite surprised how small the Phatbox internals are, the metal chassis is just 'padding' so it can fit into a CD changer bracket. I'm now thinking about re-housing mine in a custom smaller enclosure and mounting it under the seat. I really want to stealth my sub in the space currently occupied by the phatbox.
BTW......did a 40 mile round trip this morning and during this time the phatbox did not skip or jump to FM mode! This journey took around an hour and normally the phatbox would have jumped to FM mode at least once.
Will test it throughout the week and let you all know the results.
Very interesting!!! Tempted to try this, although looks a bit scary!!
Just wonder if Phatnoise will still do the fix FOC? If so I'd rather
pay the postage and get it done that way, don't really trust myself!!
Anybody tried this mod with a Gamma rather than an MFD? Is the firmware on that site specific to the MFD units only?
Also any news on whether this mod alone cures the alternator whine issues?
Just a thought, but what about making the jumped connections at the plug side rather than on the board itself - would mean making up a custom plug adapter (but this was done before anyway wasn't it with the little ribbon cables leads some people made up to mount the Phatbox further back in the changer mount). Would potentially avoid the need to void the warranty too. Presumably this is what the cutsom wiring harness suggested on the site is talking about? Would surely be a market for these is someone was to make some up to sell...
I have some spare connectors in stock, so it's possible give it a go,
though the small problem I have, is that I'm moving to work in the US
from this Sunday.
I have no problem is sending out a pair connectors to anyone wishing to try it.
Quick update.
Whilst I'm away, a good friend of mine will look into obtain some PCB
board, and ribbon cable connectors, so that the cable modification can
be done on the PCB board, and not at the connectors. This will mean
that PCB can just be used cut into the current connects that members
have previously purchased.
So as an idea, the PCB board will just contain two connectors so a simlar style to these
1 - 20 of 23 Posts
