21 - 27 of 27 Posts
Livin' by the sword
its alread got a upgraded clutch, vented and drilled brakes and im on FK coils, im just looking to get asmuch out of her as i can without having to go down the route of a bigger/hybrid turbo, what sort of intercoolers should i be looking at?
Changing the intercooler won't give you more power. What it will do is cool the charge air from a bigger turbo on a harder working engine. So consider the intercooler route when you start pushing high boost figures. The turbo will be the limiting factor there though before you hit problems with cooling. The 170 TDI uses the same intercooler so there's plenty in reserve.
Decat and a remap should see you nearly at 190-200 anyway
Hi , im looking for upgraded injectors , i have pd 140 i change turbo (GTD 2060) hybrid , remap stage 2 , down pipe , semi slicks tyres new pessure clutch everything new 270/280bhp from 140 bhp with remap on standard turbo 191 bhp and now 270 bhp i need new injectors what do you suggest ? i send mine to make them taller or i go for new ?
TIA
21 - 27 of 27 Posts
