1 - 2 of 2 Posts
Yeah you stopped the valve from opening when the system tries to engages the valve via vacuum. So that is you stopping the gasses getting in. As the valve won't opened on demand. You still need to block the gasses going through the egr feed pipe otherwise it might crack under the pressure of the exhaust gasses and the build up heat.
1 - 2 of 2 Posts
