1 - 8 of 8 Posts
Hi,
I'm trying to swap out my 2004 Immo4 TDI 2.0 clocks (midline) part no ends 960 with some Petrol ones that I bought from the US ending 971 (closest I've been able to fine). I have both SKC's, have installed the new clocks (and zero'd their mileage) and entering the soft coding from the old coding following this guidehttp://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_Immobilizer_Swapping_%28Instrument_Cluster%29 .
When I enter channel 50 and enter the code from the old cluster and click test, I get 'system not ok' error, and it fails.... My questions:
Where the guide says:
  • All relevant coding and adaptation values have been transferred from the OLD (ORIGINAL) cluster to the NEW (USED) cluster.
what does it mean? I've check the CECM coding and thats as was, is there anything I've missed. I've also heard that the mileage should be settable with VCDS, how is this done? Do I need anything extra to change them from petrol to diesel coding?
I've not managed to get the battery voltage to 12V, with a long run today it's at 11.6 and still failed, does this matter?
I've also seen (albiet for immo3), that if the clocks have been previously adapted this needs clearing, see http://forums.tdiclub.com/showthread.php?t=252638 post #15, does this need doing for immo4
Any ideas welcome. Many thanks.
Paul
i have an 04 1.9 tdi and have a highline i want to fit but i didnt get the immo code with the dials, so how can i get the immo code or is it a case of plugging the dials in and reading them? also do you know anyone who would do all the coding for a large sum of beer tokens? i will travel anywhere
I can get the code out, but the best way seems to be to read the entire imo bin file and then write over the new clocks which saves the messing about old-n07 I think it is can do it it in Kent and I'm tempted to buy the right lead from ebay but also Kent. Where abouts are you?
im in Devon but always up for a road trip
1 - 8 of 8 Posts
