Hi I have owned my golf since last October. About a month of owning it, it started to do the annoying long cranking before it finally starts. I have vcds and the only fault code it came up with was ignition switch intermittent fault so I replaced that yesterday still having the same issues. I have also had the following either replaced or tested.
new battery
Fuel filter x 3
Oil has been dropped and filter changed
Injector seals replaced
Intank fuel pump replaced
Oil pressure sensor replaced
Turbo replaced
Thermostat replaced
Earth’s checked
Camshaft/lifters ect replaced
Waterpump ect replaced
Clutch & dmf replaced
Egr valve replaced
Alternator checked
Air filter replaced
I am literally ready to set fire to the sodding thing, any help or suggestions as to what/where to check now would be appreciated.
new battery
Fuel filter x 3
Turbo replaced
Thermostat replaced
Earth’s checked
Egr valve replaced
Alternator checked
Air filter replaced
