1 - 4 of 4 Posts
Font Rectangle Slope Parallel Schematic
Hello, I changed my half-fis cluster with full fis. But I can't see the secondary display for radio (which is Gamma V) on full fis display. I connected these cables, In addition, although I made these connections and turned on the feature on the VCDS 17th channel and 50th channel, it does not work in the secondary display in the cluster. Also, i am confused because the 8th pin of the green socket of the radio is already connected with relay 452 for mfsw. When I connected to the relay's 5th pin to the radio's 11th pin, the control buttons on the steering wheel are not working. But I can use buttons when i connected to the relay's 5th pin to the radio's 8th pin. This time, since the 8th pin of the radio is full, I cannot connect according to the diagram in the picture.
1 - 4 of 4 Posts
