1 - 20 of 44 Posts
Engine out on friday.
Subframe off, fitted TT rack, whiteline arb, new arms ect.
Engine should be in this week, waiting on a power steering pipe, 1.6 pipe is miles to long.
Wow it's hot today.
Anyway, 4 motion clutch dont work with v5 box.
Orederd v5 clutch & flywheel, fingers crossed.
£400 😓 ouch
Subframe is refitted.
Loads of new bits fitted.
Try clutch tommorow, if that's a fit.
Engine will be in.
Cleaned it up, aerosol black.
Doubt it will make any difference to be honest.
Had dash lit up today, need ecu coding to car now.
Drive shaft bolts are different to all over VW, well all the VWs we have broken.
Tps want a fortune, I've got the sizes, so of to the bolt shop tommorow.
Still waiting on the gear selector, that's apparently in the post?
Repaired the lamba probes, they had been cut, doubt they will work, but worth a try.
Progress is progress
Had ecu coded to car today.
No immobiliser flashing on dash, clocks now communicate with ecu.
That went fine, but car wont start!
Thers no spark, no fault on vagcom???
Maybe coil pack?
Had a near miss yesterday.
Starter motor jammed on!
Screaming its cock off!
Smoke pouring out, aboutvto set on fire!.
Managed to get the battery leed off.
Close call!
1 - 20 of 44 Posts
