PLease Help!
I'm currently building a corrado and, nearing completion, I have come to the brakes. I have basically transfered everything from a Mk4 2.3lt V5 into my corrado, Engine, loom, brakes front hubs etc etc...the lot.
The trouble I'm having is that what ever I seem to do I cant get a good pedal feel. I have folowed the procedure I have found on the net: Bleed each corner in sequence, rear driver, rear passenger, front driver, front passenger. Then run the 'output test' using Vag Com which I'm led to beleive does its thing and creates the hard pedal pressure.
After doing this sequence I get a moderatley stiff pedal but as soon as I turn the engine on and the servo assistance come in the pedal is soo soft it could flap about in the wind! This is sooo frustrating as I have now bled the thing about six times (take shares out in brake fluid companies!)
If someone out there has experienced this before please help I really could do with an idiots step by step guide to how to do it correctly.
or if anyone out there have the bentley workshop manual on the MK4 this should detail the procedure.
Any help you can offer is greatly appreciated.
For you information the set up I'm running is:
Mk4 Master cylinder and pedal box,
Mk4 ABS ESP pump
Mk4 rear calipers
all the above is from a MK4 2.3lt V5 (2000 year)
I have front calipers from a Porsche 911 (1995 carrera - non turbo)
Many thanks,
Doug
Mk4 ABS ESP pump
Mk4 rear calipers
Many thanks,
Doug
