Fitted a recon rack 6 months ago due to old one leaking from end seals. This one is now leaking from the rack bar thrust yoke plug fitting on the back of the pinion gear housing. These are part numbers10 to 13 on the diagram. There are 2 O rings which are not clear on the diagram. Anyone had this problem and can you get a seal for it? The fluid is dribbling from 2 of the 4 holes on the perimeter of the housing where plug 11 is fitted (Arrow ) . Can get to it ok under the car and don't fancy taking it all off again.
