1 - 11 of 11 Posts
@SprintMPW
So after alot of thinking i have decided against an engine conversion and decided to buy a new car and start a fresh project.
the first car i bought was in a pretty bad way tbh i have spent alot of money on it fixing little and big problems, so the main reason for this post is to ensure i do things right.
What are the main faults /things to look out for when buying a 1.8T golf?
any help if greatly appreciated as im wanting to get a new car within the next few months
Mat [:D]
@SprintMPW
cheers mate, i have done a little bit of research on the web and someone mentioned
"n75 boost control valve fail
air flow meters prone to failing
standard d/v failures
water pump (crappie plastic type)
coil packs"
was just looking for people to confirm these.. as long as i give one a thorough check it should be fine
Mat
i love to ski, its so relaxing
im looking for a 1.8t, i'm making sure im getting a later 1.8t with the ko3s turbo, some people said its better, so thats something to consider
@SprintMPW
yeah if you can, get someone with vag com to go with ya and scan the cars you go to see!
ahh i never thought of that! i have a cheapish scanner that picks up engine faults etc works for engine, srs, abs.
also at the ko3s reply. i never knew the difference tbh. but ill have to look into that
cheers for the feedback guys, greatly appreciated
Mat
yeah you could do that but some people dont like you plugging things into the car but still worth a go.
common failures as you mentioned above, im traking it that you will want to get it mapped. depending on how much bhp you will want an agu is a better engine than an aum but with a weaker turbo only 200hp max. aum will map to 215-225 roughly but if you're looking at big power, then an agu will be better after you change it to a ko3s.
the cable throttle is better imo as it is more responsive whereas the electronic ones are a bit iffy. but you can easily add cruise control to electronic throttle but not so easy on a cable one
@SprintMPW
ye i see what you mean about people being iffy with plugging something into a car.
ye i would be getting i remapped eventually. however im not wanting stupid power(i think [:p]) im not really clued up yet on big power as my current car is my first car.
i would love to beable to know inside out of tuning but that will come with time. my ideal car would be buying it and remapping to around 240 - 250 bhp. then id leave the power side and concentrate on the looks. so maybe an agu would be ideal, depending on k03s costs.
Thanks for the reply
Mat
@SprintMPW
soo i have just found a car in my price range, ok mileage 80k, in my favouite colour jazz blueeee
its a 2001 y reg aum engine.. anyone know what turbo these cars came with?
plus its a fellow guy from ukmkivs.. who sold it to the car dealerships i saw a sticker [:p]
Mat
1 - 11 of 11 Posts
