1 - 20 of 22 Posts
Standard 16" alloys for the Mk5/Touran are ET50 anyway so I'm sure another 1mm won't make too much difference.  I'm sure 'hufcforpromotion' on here had Audi Calito alloys on his Mk5 and I think they were around ET52/3.
Can someone give me some advice please.
When I had my RS6s on mine (for all of 24 hours) the 8.5X18 was obviously too wide (hence the getting rid of). I know 8x18 is the norm but they stuck out soooo much I am wondering if I should get 7.5x18 (few designs but they do do them).
I mean, if the half an inch less on 8 width is from the inside of the hub then it wont make a huge diff from the outside profile - what dya think?
Can someone give me some advice please. When I had my RS6s on mine (for all of 24 hours) the 8.5X18 was obviously too wide (hence the getting rid of). I know 8x18 is the norm but they stuck out soooo much I am wondering if I should get 7.5x18 (few designs but they do do them). I mean, if the half an inch less on 8 width is from the inside of the hub then it wont make a huge diff from the outside profile - what dya think?
What was the offset of your RS6s you had? Foxy's Karthoums & BBS's were/are ET45 IIRC and fit fine (also 8x18). I have RS6s on my Touran and they are ET45 also (8x18) with no problems at all, in fact I've got some 10mm spacers to go on the back.
Do any of these numbers help to find the pcd of the rims?
all numbers stamped on inside of wheels are as follows.EF X TTH SC AlSi7Mg-wa K1 STTI ET51 6.5jx16H2 012 max.875kg VO 069 7H0601025D. On outer rim KBA45440.
8x18
ET51 and ET50 respectively
Foxy - so your wheels were/are not ET45. Is that why the ET45 RS6s I had stuck out so much. How come you have a different offset to what I have been led to believe is the right size for the car. I thought the Karthoums come ET45 from the manufacturer. Have I missed something - cheers mate
8x18
ET50 and ET51 respectively [:$]
Deffo ET50...............
The chap at the wheel place said the 8 instead of.8.5 width will make all the difference and not to worry about the offset. (I seem to recall "dont worry about 8.5, you'll be fine)
I have found 8 width with an ET47??
Rial do some Daytonas in the right size I think. I dont fancy the antera's much. Any thoughts
1 - 20 of 22 Posts
