Minimum wheel size for a 4 Motion
893 Views 8 Replies 6 Participants Last post by  mattblack12
Can I fit 15" wheels to my 4Motion ?
I currently have 18" but I don't want to keep them on over the winter incase I kurb one. 15" are much cheaper.
1 - 9 of 9 Posts
If your not lowered and depending on the profile of the tyre I don't see why not..
I think the size of the brakes will not allow you to go down to a 15" What size is the spare or isn't there one?
I'm not lowered, Just normal calipers on 321mm discs.
Here's a good reason - because they won't fit over the brakes.
16" is the smallest wheels you'll get on a 4Mo. 4Mo OEM Brands Hatch's should be easy to pick up fairly cheaply though.
Jon.
I was looking at a 15" set on ebay with winter tyres, 1 day auction or buy now £150.
I would have thought 16" is the minimum too, but it would be a very tight fit.
I had trouble finding 17" splits that fit over my 4 pots too so I gave up and just stuck with my rs4 reps, but even then the clearance from spoke to caliper is a bit tight without spacer.
i struggled to get 15s on my mate's standard 1.9gti, the balance weights were catching on the rear caliper on one side
Jon.
Good point!
1 - 9 of 9 Posts
