1 - 19 of 19 Posts
Its quite a good product, you should have some in your detailing box really.
i do have some mate.
i've used it several times, but never seen it actually do anything.......
Maybe that because your car is in such good nick to start with.
I've purchased some of this and plan on using it on my car this weekend, my car has lots of swirls and poor finished areas so im hoping this will help to revive it.
Ill let you know what i think once ive tried it
whats "correctly"???
i'm using a megs application pad......medium amonut on the pad......rub it on, haze appears......then buff it off......
tried it on my other halfs puma, and it dont do anything on there either.....
Ditto.... I like it and I think it works
Surely your car doesn't require Scratch X Kev ?!?! [:O] - its just tooooo clean!
nor does mine, but there is the odd minor scratch
A minor scratch should easily come out... have you just tried a polish if the scratch is minor.
sure have dude.....what "polish" would you suggest?
If I remember correctly, you are always waxing your car...... please correct me if I'm wrong.. therefore you need to get down to the paint/ clear top coat....
If you have a large build up of wax on the paint then you are just taking that off and not attacking the fault... try washing the part with washing up liquid, but be very careful not to get it on any other parts of the body work, then dry the panel and use the Scratch X, follow with a polish and then a wax or sealent or both
i wax my car probably once a month, or even only once every two months......so not LOADS of wax......
but, i do see what you mean.....and its worth a try!
(dude, you coming to the colchester meet?)
passenger door frame...the bit the goes up the windscreen... (a-pillar)?
thanks for the offer dude!...hope you can make it now!
1 - 19 of 19 Posts
